The two heater pipes that go into the firewall are disconectec
    The two pipes that go into the fire wall on the drives side, which i assume are for the heater are disconnected on my car. They are connected together. I know my heater will not work, but will this affect my A/C?
    it will not
      ^^^^^ True words - no effect on the A/C, just heat.^^^^^
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
        more than likely the core had a leak. you may want to take a look around the floor for damage like rust or mildew.
          Thanks guys :p
            Also if you have a cracked pipe or anything i would check for your recalls they may still have some for your car with the heater core bypass thingy built in and it probably will be hooked up right if they do it
