Question?
    • 37832
    Plan on at LEAST $4000 for a 5 speed swap and turbo setup. And that's cutting it cheap.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • RaZrShRp
      • Jun 2007
      • 77
      alright thanks. ill be starting it in December
      • RaZrShRp
        • Jun 2007
        • 77
        does anyone know what kinda of engine i have. i mean i know its a M20 but like can i put a different head on it. or like different internals or something?
        • SpecM
          • Oct 2005
          • 4531
          -Don't worry too much. If you want to look around you can find a s-eta bottem end (block, crank, rods + pistons, use everything else from the 2.5) from a '88 325 or 528e. It will bump displacement to 2.7 and lower the CR to 8.5:1 (from 8.8 ). That'll work well with the turbo.
          1989 cirrisblau-metallic 325i
          • RaZrShRp
            • Jun 2007
            • 77
            Originally posted by SpecM
            -Don't worry too much. If you want to look around you can find a s-eta bottem end (block, crank, rods + pistons, use everything else from the 2.5) from a '88 325 or 528e. It will bump displacement to 2.7 and lower the CR to 8.5:1 (from 8.8). That'll work well with the turbo.
            do you have to pull the engine?
            • SpecM
              • Oct 2005
              • 4531
              -No, but it would be a lot easier if you did. You can leave the naked block in the car and tap new pistons in... and the crank from the bottem but you'd have to remove the subframe... I'd pull the engine.
              • RaZrShRp
                • Jun 2007
                • 77
                what is the difference between a stroker M20 and the M20 in my car now? idk if this is a dumb question but i thought i would ask anyways. because it is confusing me.
