Can anyone explain this?
  • StereoInstaller1
    GAS
    • 22679
    From an M20B25 I got pre-dissasembled:
    Closing SOON!
    Thanks for 10 years of fun!
  • whiltebeitel
    • Apr 2007
    • 2098
    Aer you meaning the wear on the camshaft or what looks like a flat spot on the lobe?
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • JasonC
      Site Manager
      • 14451
      Looks like a worn lobe, time for a higher lift cam.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
        • 34839
        the oil tube that runs over the cam will clog eventually, esp. if you use crap oil and don't change it very often. that's likely what caused the cam to wear like that, judging from the amount of sludge in that picture. the flat spot is probably just where the heaviest load on camshaft lobe is located, so it wore away faster there.
        • Sean
          • 5793
          Yea, that's a nice edge right there. Ouuch.
          - Sean Hayes
          • Jordan
            • 12912
            Yup, thats pretty much it. I'd recommend a new camshaft. Used stock in good shape or a new Shrick billet made to your specs from TopEnd.
            https://mtechniqueabs.com/
            • StereoInstaller1
              GAS
              • 22679
              I was given a shell (91 325i) to "dispose" of.
              Motor is just fucking wasted.
              I am hoping the head is OK other than that nasty ass cam and the equally nasty rockers...since I just happen to have spares.
              I might build this car as a swap, M50 and 5 lug, or just make it stock and sell it. The body is pretty clean, the front bumper is cracked but the rear is fine. Left fender is crumpled, but tons of other stuff is pretty decent.
              Dunno, just sitting on it for now.
              Luke
              Closing SOON!
              • browntown
                • Jun 2004
                • 3524
                get back to work! mach schnell. :-)
                  • 34839
                  the head might be ok for a rebuild, as the cam bearings get their oil seperately from the cam lobes. the only way to know is to take it apart and check out the bearing surfaces.
