Bizzare M20 issue
  • Funkmasta
    • May 2004
    • 7185
    Bizzare M20 issue
    Car - 89 325i 5speed 180k
    Will run GREAT when the motor is cold. Once the motor warms up, it STILL runs great, but will once in a while die, when coming back to idle. At THAT point, it won't start for 2 minutes to a half hour.
    What gives?
    We cleaned the ICV, swapped the DME, swapped the crank pos sensor, swapped the Motronic temp sensor, and swapped the air flow meter.
    (We also swapped the coil).
    Once it starts again, the car runs great! and will run for another 5 minutes then die.
    wtf? help?
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • Funkmasta
    • May 2004
    • 7185
    swapped in a third DME, and it seems like it is fixed...
    That Guy.
    • Van Westervelt
      • 9365
      problem is, its an m20. :)
      • backtrail69
        • Jul 2005
        • 4471
        The problem is motronic.. I hate that system. You can't see whats going on at all. Standalone FTMFW!
        :: PNW Crew ::
        '87 325 4dr, '74 2002
