Having problems pulling engine + tranny at once
  • mspiegle
    • 1026
    Hey all,
    I'm trying to pull an engine & tranny in one piece from a doner car. I have NO idea what the heck is going on... here's a summary of what i've done for prep work:
    1 ) Removed ALL accessories (ac, alt, ps)
    2 ) Removed cooling/radiator/hoses/heater hoses/etc
    3 ) Removed all electrical connections
    4 ) Removed exhaust manifolds/headpipe
    5 ) Detached tranny from driveshaft as well as shift linkage
    6 ) Unhooked slave cylinder line
    7 ) Anything associated with the throttle body/throttle cables
    8 ) Removed front crank pulley
    I've got an engine lift, load leveler, lots of chain/hooks/etc. I put a hook on the front mount, and another hook on the rear mount near the starter. When I start pulling the engine out, it comes up all at once instead of just the front.
    Do I need to remove the front crossmember or swaybar?
    I tried doing a quick search, but couldn't find anything. If you've got a writeup you can point me to, i'd be more than happy to read it. Thanks!
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
  • PeaveyBassist
    • Sep 2004
    • 3511
    Put the load leveler on it. Angle the front up a LOT. Move forward, angle up, move forward, angle up, etc. Youll get it.
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • Teaguer
      • Sep 2004
      • 6167
      ^ yes either that or for more clearence and simplicity just put the hook on the on the strap directly . No leveler .
      Will angle straight up and come out like a champ .
      I've pulled dozens of M20 with trannies this way and the only tight spot is the power steering pump pulley to the core support .
      • mspiegle
        • 1026
        Interesting...
        Alright, I'll need to try this again. Do you guys normally take out the swaybar?
        Thought: I just realized I didn't take the bump-bracket thing (supports the transmission's forward movment against the crossmember), and that might be hitting something.
        Thanks guys!
        Michael Spiegle
        '99 M3 / Track Car
          • 37829
          I always use the front hook only for a motor and tranny pull. If it's an auto you may have to disconnect the swaybar to get some more room.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • AndrewBird
            The Mad Scientist
            • 11898
            You didn't say you did, so I'm going to ask. You disconnected the motor mounts and the tranny mounts, right? :)
            • mspiegle
              • 1026
              Seriously?! Entire thing from just that front hook? I thought about doing that, just seemed kinda.... dangerous.
              Michael Spiegle
              '99 M3 / Track Car
              • mspiegle
                • 1026
                That I did :)
                However, you reminded me that I forgot to undo the reverse light stuff. I'll be taking another whack at it this weekend.
                Michael Spiegle
                '99 M3 / Track Car
                • NC325iC
                  • Mar 2004
                  • 6565
                  when i pulled mine i had a chain from the rear to the front and hooked the hoist up very close to the front
                  i also forgot to unbolt the slave cylinder hose...
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    I forgot the engine shock on my m10.
                    • rcko
                      • Mar 2007
                      • 295
                      ditto on the front hanger only. I was skeptical when Teaguer recommended this during my engine swap but it worked like a champ.
                      The only thing to watch out for are the PS pump hoses haniging on the engine mnt and the power steering pump pulley unless you disconnect that and leave it in.
                      ALso when putting the engine back in this way watch out for the rear engine coolant port on the head and the firewall. DOnt crush it or break it.
                      - 0.05s and 0.1s FTW!!!
                      • golde30
                        • 11464
                        i just pulled my m20 last week. it was my 4th m20 pull. this is how i did it every time.
                        1. disconnect everything, also remove the shift lever.
                        2. jack up front of car only, and place jack stands under frame rails.
                        3. connect chain to front and rear of engine, load bias towards the front
                        4. start jacking up the motor enough to get it off the mounts
                        5. yank the hoist forwards to dis-lodge the motor, get front of engine almost touching rad support.
                        6. jack up car from subframe, remove jack stands, now slowly lower the car, and watch as the engine removes itself from the engine bay.
                        7. jack up engine as high as it will go, level it out, and voila, yer done.
                        8. smoke ciggerette, drink beer of choice.
                        NOTE: insert massive yanking on motor/hoist where needed, inser curse words wherever appropriate.
                        PS: i have pulled the motor from that weak looking think hanger before no problem, but this time, it bent on me, so im back to using the rear also.
                        IG: @Baye30
                        • mspiegle
                          • 1026
                          Awesome feedback! Thanks guys. I'm about to take another stab at it in an hour.
                          Michael Spiegle
                          '99 M3 / Track Car
                          • mspiegle
                            • 1026
                            Success!!!!!!
                            So I think a combination of removing the crash-stop thing on the bottom of the transmission and using a jack to help it clear the front subframe is what ended up finishing the job. You guys are right... using JUST that front hook is a good way to get it started. As I got the whole thing up, I had problems clearing it over the front of the car but my lovely assistant helped pull the hoist back as I lifted the transmission over it.
                            Following are a few pix of removing the engine and a few gooberish pix of myself. I also bought an engine stand so I could do some work on the engine while it was out. It was well under $100 from the local auto parts store and decently does the job. There are 4 arms that you position and bolt to the engine, however I was only able to get 3 attached. If any of you ever buy an engine stand, make sure it has a huge amount of adjustment. You can kinda see it in the last picture.
                            Michael Spiegle
                            '99 M3 / Track Car
                              • 37829
                              I swear I've done the same thing almost every time, lol.
                              Grover Beach, CA
                              www.BimmerHeads.com
