does a 325I head fit on a 325E block?
  • zwilson8806
    • Sep 2007
    • 13
    Does a 325I head fit on a 325E block. My 325E's head locked up and snapped a couple valves and the head is toast. I have a 325I head that I have done some head work to and Im wondering if it will fit on the 325E block, and also how much I can bore the 325E block since it now has scuffs on the cylinder before I hit a water jacket.
  • Jordan325iC
    • Aug 2005
    • 1697
    It will bolt on to the block. The compression will be a bit low, but it will run. The 2.7i "stroker" is actually a pretty common modification, but it requires a few more things, and it will get you approximately the same horsepower as an "i" engine.
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
    • JasonC
      Site Manager
      • 14451
      dyno of i head on e bottom end.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • AndrewBird
        The Mad Scientist
        • 11898
        There are a few oil passages you have to drill to make it work I believe. It's not a direct swap, but doable.
        As far as boring over, I would think 0.030 would be max, but don't quote me on this.
