# of teeth on t-belt matter?
  • vic_325
    • 264
    im going to do the t-belt on my 87 325i, but when i went to get the belt i had a choice of 127 or 128 tooth belts, does it matter which one i get? how can i tell before taking it off and counting.
  • naika
    • 466
    I didn't know there were too teeth counts. WOuld that depend on if you have an ETA or I engine?
    I only had one option when I bought mine
    344is! Obd1 conversion
    • CarsSuck
      • Oct 2005
      • 968
      Maybe you should check around with some other parts retailers. T-belts are cheap, maybe just buy both and compare then return one.
      --Will
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        x2
        Here in the shop a quick way to verify t-belts is to mark one groove with whit-out or other type marking material. place the new belt and old belt rib-to-rib. then while holding both belts, complete one full "meshing" back to the white-out. If you are not aligned with your marks, the belt is not correct.
        • wayfast
          • Mar 2005
          • 178
          your tenisonor will say 127 or 128. get whatever belt it says.
          • James Crivellone
            Head Janitor
            • 6303
            buy the entire kit, which includes the belt and tensioner... Its quite a bit easier!
