HELP!! my car sounds like a subaru...
  • E30FreaK89
    • Apr 2006
    • 437
    just that, tonight i pinned full throtle and then slamed in second and punched it again. the back end slid a little with tire spin and then after it started sounding like a subaru! it feels like one of the cylinder's isnt fireing..i was just woundering if anybody else has had this problem?
  • e30 gangsta
    • 3877
    sigh. Check everything then get back to us. No one here is going to throw on random suggestions to help you out. Post more info.
    • asubimmer
      • 6482
      broke a rocker arm prob...
      • mark247
        • Nov 2007
        • 107
        Sounds like a broken rocker. I remember seeing a video on youtube or something a while back of a e30 sounding like a subaru, i think it was a broken rocker arm so yea.
        • SchnellerVert
          • Sep 2005
          • 3948
          did you look under the hood?
          • Jordan
            • 12912
            Broken rocker is most likely.
            Just pull the valve cover off and have a look.
            https://mtechniqueabs.com/
            • NC325iC
              • Mar 2004
              • 6565
              what do you mean sounds like a subaru, that is really an odd description of a sound
              • asubimmer
                • 6482
                never heard a wrx?
                which also means trivia time...
                who knows why wrx's sound like they do
                • E30FreaK89
                  • Apr 2006
                  • 437
                  yep broken rocker arm on the #4 cylinder...now it looks like i have to pull the head off to get a new rocker on there? or is there a sneaky way to do it?
                  • Jordan
                    • 12912
                    If you want to make it a long, cumbersome, draw out process.... you can change it in the car.
                    I much prefer to pull the head to do it. It doesn't take long and you can replace worn seals and the like while you are there.
                    I prefer to pull the head with the intake manifold and exhaust manifolds still attached. This saves you alot of time, labor, and the cost/time of replacing those gaskets. The downside to this is the entire assembly is pretty heavy and although you can likely lift it up and off, and hold it at your chest fine.... holding it with your arms stretched out trying to lower it steadily onto the block to put it back on is near impossible. With a friend on the other side to help its cake.
                    Do yourself the favor while its out and replace all 12 rockers with new ones. You'll never have this problem again. They way it sounds like you like to drive, with these rockers age, they are all just waiting to follow suit.
                    • E30FreaK89
                      • Apr 2006
                      • 437
                      with that being said.. i dont want this to hapen again, is there a beter stronger rocker arm and valve spring i can go with to handle higher RPM's? i know there must be, can you please send me a link to a place that sells them.. thanks, i was also looking into stroking my car after i did my suspension but it looks like im going to be doing the stroker first, soo ill probubly be pulling the motor..
                      Gary
                      • Dave
                        E30 RAT
                        • 11675
                        Yes, there are stronger rocker arms - do a search here and you will find them. Not sure they are really worth the extra $$ unless you are going mad forced induction though.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • mark247
                          • Nov 2007
                          • 107
                          Originally posted by asubimmer
                          never heard a wrx?
                          Boxer engine with horizontally opposed pistons and a massive ass bigbore exhaust with "RICER" stamped all over it, thats why they sound like that =P
                          • E30FreaK89
                            • Apr 2006
                            • 437
                            ehh....i would'nt consider a STI a ricer considering that they acually go fast....
                            • Bimmerista
                              • Nov 2005
                              • 5425
                              +1
