Cold Oil pressure
  • nefarious7907
    • Jan 2005
    • 1170
    Cold Oil pressure
    So I finally got around to getting my SW Oil pressure gauge hooked up. And although it was about 30 degrees outside it was reading some 90psi on a stone cold start is that normal? after a minute or so it was down to 75psi at idle and dropping.
    I am using non synthectic BMW 15-40w oil, and I have a rather large oil cooler fitted to my m20.
    http://www.cardomain.com/ride/657387
    • 34847
    yes
    • nefarious7907
      • Jan 2005
      • 1170
      ::sigh of relief::
      • JRKOUPE
        • Dec 2004
        • 3159
        op
        Originally posted by nando
        yes
        +1
        • PeaveyBassist
          • Sep 2004
          • 3511
          Mine at cold start is around 60-70psi. When it warms up (15 min or so later), around 20psi at idle.
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • 34847
            you oil warms up in 15 minutes? my coolant takes longer than that to warm up...
            it also depends on what you're using - lighter oil will have lower pressure on cold starts than thick stuff.
            • PeaveyBassist
              • Sep 2004
              • 3511
              Well in 15 minutes probably its about 20psi. Coolant is warmed up in 15 though :) When my oil temp is around 190deg F pressure at idle is about 20 psi.
              DaveCN = Old Man
              • nefarious7907
                • Jan 2005
                • 1170
                It takes almost 20 minutes to get my oil temp up to 170 degrees on a 90 degree day, I havent seen my oil temp gauge go past 150 now that its freezing out. And when oil is 150 degrees I am getting around 50lbs of oil pressure.
