wierd idle
  • kamotors
    • Nov 2007
    • 7102
    #31
    still haven't had time to put the new injectors in yet. but i cleaned my ICV,AFM, and air filter and my car ran super amazing today,maybe i didn't have leaky fuel injectors....my car spins the tires and fishtails (on DRY asphault) when it shifts into second every time i floor it and its an automatic. could a dirty ICV cause hard starts when warm. no idle problem at all today
    7speedshop.com
    • alpinaclone
      • 820
      #32
      forget it, read the rest of the thred....and then felt dumb.
      Matt
      • kamotors
        • Nov 2007
        • 7102
        #33
        okay the idle problem came back...? should i clean the ICV again, but i haven't had a single hard start at all.
        7speedshop.com
          • 34844
          #34
          have you tested your coolant sensor or adjusted/tested your TPS?
          • kamotors
            • Nov 2007
            • 7102
            #35
            no, I bought a new coolant temp sensor but haven't been able to put it in, it just snowed another foot on saturday.( never put a car cover on if its going to snow a foot, the cloth will freeze to your paint and make your car fuzzy untill all the snow melts.) it only has the idle problem in drive.
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #36
              today i left the key in the position right before starting and then when i tried to start, it took a while. bad FPR maybe to much pressure
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #37
                at idle if i give it gas the rpms drop then go up. if i rev it then rev it before the RPMs go back to idle then its fine but from idle it has really bad throttle response. normally you give it gas and rpms go up, for me i give it gas and rpms go down then up.......went for a drive did 2 0-60 runs went racing through the local windy road came home and now the throttle response is amazing compared to what it was before...E30's just have there days i guess.
                7speedshop.com
