awesome thread
informative, been reading and makes me want to work on my eta right now haha
I'm in the process of getting a complete 89 325iC from someone for my 84 325eta. I know it was mentioned here that everything is pretty much swap i parts to e with NO machining or custom pistons (unless you want to) needed right? I also saw that bolting a stock i head to eta block will be a low CR, which is fine because i plan to turbo the car later down the road BUT it will cause the car to have rough idle and hard start.
Would buying a chip fix this issue? I'm trying to avoid any machining work because I don't have access to one and I know they can be pricey but IF i do, what part specifically and what machining needs to be done? and if so, how much you reckon it would cost? Thanks
