I've had this problem on and off and i'm getting fed up with it. Maybe someone else had the same issues so if you could share any info on it?
Cold starts it alwats starts perfect. Sometimes when you start the car on the cold start and then shut it off right after it would crank forever untill it starts again. The other times the car will be completely warmed up and i will shut it off for few minutes to run into the store and it will also have those symptoms. It doesn't happen all the time though.
Few days ago it finally let me down and my battery obviously died cause i cranked it too long. I pulled out the sparkplugs and they were soaking wet with fuel. I did the injector flush already and that didn't help. It happenned today again. I had to step on the gas pedal and hold it down while cranking and only then it started. I smelled unburnt fuel from the exhaust.
So what do you guys think it is? Leaking injectors?
Maybe i'm not getting spark? I didn't check for it by trying ground the wire with the plug. I know sometimes you can see a spark but its not strong enough to ignite the mixture.
Any info is appreciated.
