Battery draw
  • samryerson
    • 3
    Battery draw
    1988 325iX:
    Battery has low charge after sitting overnight. Voltage drops to less than 12.
    Brand new battery.
    Alternator charges at ~14 volts.
    With negative terminal disconnected, test light shows draw even as each fuse is disconnected and with alternator wiring disconnected.
    Where is the draw?
  • Jordan
    • 12916
    are you sure the battery doesn't simply have a bad cell?
    https://mtechniqueabs.com/
    • Tarn
      • Sep 2006
      • 212
      check trunk, door and glove box light switches.
      • xLibelle
        • Aug 2004
        • 2673
        pull ALL fuses, one by one and DONT replace until you have the light go out...
        best tool to use is a meter, not a light.
        • kenika65
          • Aug 2007
          • 1336
          Flash light in glove box!
          1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
          1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
          • DaveSmed
            • Apr 2007
            • 1407
            +1, remember to hold the trunk switch in when you are checking this stuff, as the trunk is obviously open.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • samryerson
              • 3
              solved
              thank you.
              it was a loose connection to the aftermarket radio.
