Q: Water Pump - Dry vs Sealant?
  • funcrew
    • Jun 2007
    • 1223
    What are the pros and cons of gooping up the water pump gasket prior to installation? If recommended, what goop would be best? BTW I cleaned up the seating surface super nice with a razor blade scraper.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • DaveSmed
    • Apr 2007
    • 1407
    There's this stuff called high tack, comes in a can similar to the one anti-seize comes in. Good stuff, makes a wicked mess. Fresh stuff isnt too bad, but the old stuff is great for making a small disaster wherever its used. Works though.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
      If both surfaces are perfectly flat and smooth no sealant is needed. But that's seldom completely true, so a bit of sealant is a good idea. Most any auto parts house will have an elastic sealant specifically for cooling system service, which would be the best choice.
      • FredK
        • 14761
        I like using Hylomar HPF from Permatex. It allows you to immediately put the car back into service. Not only does a little go a long way, it is around $3 at any generic auto parts store.
        • makaio
          • Nov 2007
          • 135
          That's what I use. IMO you should at the min. put it on the water pump side and put the gasket on the water pump before installing it on the block. This will keep from pinching the gasket when installing it.
          • funcrew
            • Jun 2007
            • 1223
            Thanks to all. I ended up using a tiny $5 tube (that will last what's left of my lifetime) of a Permatex product specifically marked for use on water pumps.
            -Dr. Paul Forrester
            • whowhatwhere
              • Aug 2007
              • 259
              I use Loctite 574
              • rcko
                • Mar 2007
                • 295
                You can also use thicker gasket paper. The permatex should work fine.
                - 0.05s and 0.1s FTW!!!
                • AlarmedBread
                  • Sep 2006
                  • 1510
                  I just used the regular gasket and no problems. :o
                    • 37833
                    Hylomar FTW
                    Grover Beach, California
                    BimmerHeads.com
                    • Schneider325
                      • May 2004
                      • 3818
                      Any harm in using Curil K2?
                      • Stevie30
                        • Apr 2007
                        • 1534
                        RTV silicone; good up to 350 deg. F
                        1991 325ic and 1991 318is
                        • Madhatter
                          • Oct 2004
                          • 966
                          non hardening aviation cement is what is normally used, #3. Its thick brown (looks black till you spread it, then its dark brown), kinda the consistancy of molasses. Permatex (along with others) make it and pretty much everyone i know in the industry will just chuck you a bottle of the stuff the minute you mention fitting a waterpump.
                          Silicone is something you never want to use anywhere near a circulatory system though. It beads when squished between surfaces so it can end up setting and floating around the cooling (or oil, if you use it there) system causing blockages. Hard setting agents should be used in place of gasket, not really combined with. Every manufacturer ive worked with has used a non setting agent to help locate the gasket in place and provide an extra layer of protection. What you use is up to you, but stay well away from a dry silicone.
                          Just a little project im working on
                          - http://www.lse30.com -
