need help diagnosing problem.
  • rakobassist
    • Nov 2007
    • 37
    i was having some fun sliding in some turns last night, and when i went to clutch kick i think i revved the motor to high.
    cause now it clicks somewhere in the intake manifold it sounds like and when the clutch engages the motor seems shaky.
    so far i think its either an exhaust leak somewhere or a blew a valve spring.
    help!
    i need to disassemble this asap so i can have it in running condition.
    if i did blow a valve my friend offered to port the head.
    btw the engine is a 2.7 m20, built by jesse30.
    2008 Sentra Spec V ( Header Back Exhaust, Coilovers, Rays Engineering 57f 18*8.5 awaiting tires)
    1989 BMW 325i (is leaving soon...)
  • Devil Inc
    • Jan 2008
    • 802
    Check your motor mounts, just to eliminate the possibility. Also, if you think you blew a valve pull the vavle cover and check the springs, etc.
    This is kinda out there but possible that could be clutch/flywheel related?
    Just some ideas. Oh and good luck in your hunt.
    P.S. I had a '97 Dodge Neon w/ auto to manual conv. and I had the flywheel bolt back out of the crank on me. :crazy: I luckily wasn't on a public road, but it happened in a store parking lot. I was barely able to hump it into a parking spot.
    • rakobassist
      • Nov 2007
      • 37
      i blew a valve!
      thank you for the heads up.
      i do not really know much about this engine at all. my friend and i are gonna pull the cylinder head and possibly port/polish it while we are at it.
      i know more of 93 mr2s and b16s and stuff like that...
      • alpinaclone
        • 820
        pull the valve cover and check for broken rocker arms, they don't tolerate being over
        r3ved too well.
        Matt
        edit: oops too late
        Matt
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          bummer.
