I Radiator into an ETA
    Anyone know if i can do this? I have used the search feature and found that they are different but no one has said whether or not you can used one in the other.
    Im sure with some cleaver hose routing that anything is possible.
    Originally posted by vlad
    yes it is possible just get i hoses and wire up the temp sensors! why are you swaping?
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      Found a new [in box] 325i radiator for $50 locally, and the radiator in my ETA is clogged
        couldent it be the same if its a pre 88 car?
          In my case i dont think so
          radiator is for an 88-91 325i, my ETA is an 86
            Put the i radiator in and buy all i hoses and wire it up you will be good to go it will bolt right up and even a e36 radiator will slip right in
              You'll want the late model i metal tube thingie, the water pump and t-stat housing from a late I as well to do it right.
              But who am I kidding, you'll just slap it together.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
                bump
                question tho i just got a radiator from a 87 vert and am looking to put it into my 86es the hose routing looks the same but there are 2 plug sensors on my radiator now but only 1 on the new radiator can it still work i got it for 20 bucks almost new ???
                TIA
                josh i
                  You can make it work, but you'll need to get the dual thermo switch connector from an 87, or later, and splice in in to replace the pair of thermo switch connectors.
                    this is coming from the guy with the "rare and sought after custom euro grill" ziptied over the stock one
                    qft
                    Originally posted by kronus
                    pff, all of you are slow as hell anyway. Eta > all
