$100 Reward For Right Answer
    If the injectors are firing like he said, the harness connector is ok.
      Did you figure it out yet?
        unplug OBC relay (or plug it in)... sounds like a factory fuel cut, that maybe got cut or tapped into while bypassing the neutral safety switch
        Joe Funk -- Portland Oregon
        That Guy.
        03 X5. 3 liter obviously.
          So do we have to start bribing with money to help each other out in the community? ;)
            i was losing ground, somehow my fuel pump was getting weak ground first, so i rewired it, then the ECU became a weak ground to the fuel pump relay, I'm still figuring it out, ECU checked out good as I plugged it in into another car, so I'm checking wires and grounds all over.
              damn it, I was going to say check your grounds. That's my favorite electrical answer.
              The bass knob doesn't work and my left headlight is out = you gotta bad ground!
