wiring help.
  • frantic
    • Mar 2008
    • 62
    wiring help.
    To start of, I am swapping my m20b20 engine from my 1987 325i (engine was put in by PO when original died), into a new 1989 320i body I bought (because mine has a twisted chassis from me rear ending someone...)
    Anyways, I have just finished stripping most stuff out of the engine bay of the 320i body, so it can be repainted in diamond black metallic (its the blue color atm). Well anyway, I have noticed a few things that I need help with.
    1. My Coil sits on the left side of the engine bay (next to alternator) in the 325i, the 320i has it on the strut tower of the right side by the washer fluid thing.
    Thing with this is it got me looking and I notice the wiring loom must be different, Since the wiring for the coil comes out close to where it comes from the firewall, so I don't think there will be a chance I can put it in the same place as it was in the 325i right (since the plug for the coil to the distributor is shorter)
    2. This bodys exhaust had a catalytic converter thing, with an oxygen sensor, so the loom has the wiring sensor plug for it. Again, My 325i body does not have a oxygen sensor so I do not need it. So I guess this loom has sensors and stuff I do not have. I also noticed the plugs look different on the 320i wiring loom, compared to the one in my 325i.
    BUT the thing is, this m20b20 engine that is in my 325i was aparently from a 1989 320i, so I thought the conversion should be fine. But what am I suposed to do? Will the wiring loom fit or am I going to have to change wiring looms?
    If I have to change looms, how do I rewire everything (the loom part that connects to the fuse box is different).
    Maybe it is different on an non-US model, but my 87325is (and every other of similar vintage that I've seen) has the coil mounted between the expansion tank and washer fluid reservoir on the right (exhaust) side of the engine bay. Perhaps things got relocated when the M20B20 was transplanted into the 325i?
    • frantic
      • Mar 2008
      • 62
      Yeah that may be, because I have always seen the coil by the washer fluid too, But the wiring for the coil comes from the loom, and if it can reach all the way to furthur than the alternator then it must be different.
      My 325i is a euro body, the 320i was a jap imported model so that may the difference?
      I guess I could always just transfer my loom but I have no idea how to do it, and what re-wiring would need to be done in order to connect it to the fuse box etc etc.
      • FredK
        • 14759
        On the 320i loom, what shape is the connector that connects to the fuse box?
        I assume the 89 has a 20 pin round connector. Does your 87 have a rectangular connector?
        • frantic
          • Mar 2008
          • 62
          Yeah it is a circle one on the 320i loom, the 87 has a rectangular one.
          • frantic
            • Mar 2008
            • 62
            Would the only change required be something along the lines of changing in my 87 ECU, putting in the wiring loom from the 87, and connect the wires to that round connector so it can plug into the fuse box?
            Does the wiring loom plug in anywhere else, Or does it just go from the ECU to other various places under the dash too?
            Sorry I am real bad at this, This is the first engine swap I have tried but I am trying to work everything out before I start it, The car is being prepped before anyhow (paintjob etc).
            • frantic
              • Mar 2008
              • 62
              bump
              • frantic
                • Mar 2008
                • 62
                Care to elaborate?
                Like where can i find the pin-outs for the rectangle connector??
