hey guys quick question
  • charlieboypr
    • Mar 2008
    • 18
    quick question guys where is the idle speed control unit located???
    I don't think your 87 has a separate Idle Control Module. That function is in the DME on this, and later, cars.
    • charlieboypr
      • Mar 2008
      • 18
      well the wiring diagram says it has one and if not, the ecu is the one that controls the idle control valve am I right?
      • James Crivellone
        Head Janitor
        • 6304
        all 84 - 87 E's had the ICM.
        Look where the ECU is (above the glovebox, behind the plastic trim), you should see a small green box with a harness to the left side of it.. that is the idle control module.
        • charlieboypr
          • Mar 2008
          • 18
          ok thanks a lot james
          • indecline
            • Sep 2007
            • 244
            Well 87' E30s have a Cold Start Injector that Regulates the Idle Control in a way.
            1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
