Is it possible to install a set of pistons and a crank without pulling the head, going through the bottom? And if pulling the head is necessary is the old head gasket reusable?
Crank and piston install.
I would just pull the head and go at it from the top. I personally wouldn't reuse a head gasket, you can get them from PelicanParts.com for about $20 iirc. You'll need new head bolts also, old ones are a one time deal. Also, from the engines I've seen internally there is less stuff to possibly damage on the top of the block. Hope I've helped. -
On BavAuto the whole to end gasket set is about $85. It includes gaskets for the intake, head, exhaust, various small gaskets, valve cover. So if the gaskets on those parts are old/original then maybe that is what you should buy. So with new head bolts your looking at around $100 or so plus little other thing you might need. Since you are looking to build a stroker, you might want to grab some "metric blues" for head bolts.
What size/type stroker are you looking to build?Comment
