My friend is in the process of doing the 2.7i swap . The 2.7i was in a plastic bumpered 90 325is that was running and purchased by my friend . My friend pulled it and put it into an 88 325e . The problem here is everything is hooked up right but there is a short. A wire on the main relay is smoking its red/yellow wire. Is this because of a compatibility issue. Will he have to put the SETA wiring harness onto the 2.7i to make it work with the 88 325e chassis. Everything looks like to be plug and play but we are having this issue. I have looked at many wiring diagrams and dont see a red yellow coming out of the main relay WTF is going on .....
Cliffs:
-325i head on top of a 2.7 block came from running 325i 90' (plastic bumper)
-Using 173 ecu from 325i along with harness
-trying to swap in 88' 325e and having issues....why?
Cliffs:
