oil cooler retrofit
  • abepark
    • Feb 2006
    • 384
    oil cooler retrofit
    hey so the other night my oil cooler fell off and ripped apart the Q I have is there a way to retrofit my car without an oil cooler without getting a whole new oil filter housing? can I splice the oil lines that come off of the housing and splice them together with a compression fitting or something like that. I'm doing a 5 speed swap and thats my down fall right now if I can't get that fixed in time for work monday.
  • papajetta
    • Jun 2006
    • 155
    u can do that. however, i did a 5 speed swap about a month ago, and ive been thinking of using the trans oil cooler as the engine oil cooler. which would give me room for a front mount..... more to come.
    • abepark
      • Feb 2006
      • 384
      so what have people done to there engine oil cooler to get rid of it? can you plug the oil lines? or is that part of the flow of oil to the engine?
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        I believe you can plug them right at the filter housing and not worry about it. But I'd run a short u-shaped line instead, just in case.
        ^papajetta, I've never thought of running the engine oil through the trans cooler/rad, but that's an interesting idea. Le tme know if it works out for you, I'm doing a swap soon too.
        • kenika65
          • Aug 2007
          • 1336
          If you dont want a oil cooler use an eta oil filter housing, eta's dont come with oil coolers.
          1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
          1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
          • abepark
            • Feb 2006
            • 384
            its not that I don't want one, I did a little off roading the other night and broke it off....and I need my car to run by monday.
