well i put the new tranny in my 325e and a clutch kit and i go to bleed the master cylinder and the slave cylinder and at first i was getting no back preasure on my clutch pedal and after i still have no back preasure...well i was looking in the bentley and it said that the bottom of the clutch pedal should be about 10 inches from the fire wall and mine is only about 7, then i read on and it said that there is an ajuster on the master cylinder so i was looking at that and mine doesnt have a threaded rod for adjustment...so basically my question is how far away is your clutch pedal from your firewall?, and does anyone have an adjuster on the top of your master cylinder?...also if you all have the same shit as me what do you think it could be?, i just replaced the slave! and i am going to be pissed if i have to replace the master cylinder! Thanks
-Eli
-Eli
