I have this rattle when the car is warmed up and stopped at a light/drive through etc. It does it in neutral but when the clutch is disengaged it goes away. Haven't had a chance to get my dad to look at it but anything I should go out and check out?
Rattle while stopped
Any easy fix? I mean it drives fine and theres no drivetrain vibrations just sometimes it bothers me, well not me but the passengers. Kids today don't respect stuff like an E30 they like E90s.
Drift- I have no idea, its sort of a frakencar since Im owner number 10-12. I change everything out with OEM as it goes bad but Im not sure what camre with the car and what didn't. Odometer says 160K but I broke it about 15K ago so maybe 175-180. Still chirps the bottlecaps into third though. Now with 225/45s it only does second so I think the engine and tranny is in decent condition.sigpicComment
Both of my e30's have the input shaft noise. They've been fine, no problems. I really don't think it's an easy fix, if you want it gone. Most likely tearing down the trans...Comment
You might try changing the transmission fluid to Redline MTL. It seems to help quieting down input shaft rattle (and makes shifts easier).
If it doesn't bother you, but you collect comments from passengers, tell them that that lightweight racing clutch/flywheels always have a rattle when in neutral and the clutch engaged.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
I think that's only the earlier tranny's. I've got MT-90 in mine and it was like flipping a switch - getrag rattle GONE. And their diff fluid made my 3.73LSD butter.Originally posted by chileelkyamaze about the enthusiasm e30 generateComment
THanks, I guess I will just live with it. The racing clutch is needed with my extra rich fuel mixture that smells in the cabin because of my supercharger wheel bearing whine.sigpicComment
