So I was driving home today and my clutch pedal dropped to the floor however I could pull it back up with my foot and drive a little further. I didn't wanna drive to far in fear that is would damage my transmission. I thought maybe there was air in the lines so I tried bleeding the system.... unfortunately nothing came out of the bleeder valve, and when something finally did it was a very weak drizzle. I had my friend just keep pumping the pedal when the valve was closed, but whenever I opened it, little drizzle. Could this be a faulty master cylinder or slave cylinder or something completely different? Any help would be much appreciated. Thanks everyone.
Clutch Pedal drops to floor (master or slave?)
Yes, it could be either.
Did you check your brake fluid level? Remove your lower knee bolster and look at the master cylinder to see if it's wet/dripping fluid. Look at the slave cylinder to check for the same. Top up the brake fluid and rebleed the system. It's kind of a pain to bleed the clutch manually, but keep at it. Find which one is leaking and replace.
-Erik -
I would suspect its one of a couple of things....
1) Your slave cylinder is shot, or
2) You have a lot of air trapped in the hydrualic lines of the clutch itself
If it happens to be scenario #1, just go buy a new slave cylinder - there may be rebuild seal kits out there but in my opinion a replacement is the best piece of mind approach to take.
If it happens to be scenario #2, check every hose fitting and make sure they are all seated tight with a good seal. If any of these are loose or the seal(s) are bad, this could be the source of the problem. The slave cylinder circuit is tied in with the fluid reservoir for the brake fluid.....so check around the master cylinder as well for any suspect problems. If your cars' brakes are still operating fine and only the clutch is acting up, you can rule out your master cylinder being shot.
JonRides...
1991 325i - sold :(
2004 2WD Frontier King Cab
RIP #17 Jules BianchiComment
Jon
I hope that all made sense...
-ErikComment
Thanks for all the great suggestions. When I look at the slave and master I don't see any leaking or dripping and my reservoir is filled to the max line and my brakes do work well. I did bleed the brakes a couple days ago and was wondering, if I let too much air in the system would it find its way in the clutch line and cause problems? If on of them is fouled I'm hoping it is only the slave because it seems easier to replace and a heck-of-a-lot cheaper than the master.Comment
So, you bled your brakes before your clutch started acting up?
Bleed your clutch and you will probably be fine.
-ErikComment
Since the problem occurred a few days after bleeding the brakes and while driving the car, the cause isn't air in the clutch system as a result of the brake bleed. If that were the cause you'd have have the symptoms as soon as the brake bleed was completed.
If there are no leaks at the slave cylinder or in the lines, the cause of this is a failed master cylinder.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
from what all of you have said, it sounds to be like a bad master cyl. would a bad master also make it so very little to nothing would come out of the bleeder valve on the slave? I might just end up replacing both while I'm down there. Thanks again for all the help.Comment
A bad master won't generate the pressure necessary to operate the slave and may not push enough fluid to the slave for a pedal bleed. That pretty well matches up with your symptoms.
The usual cause of a clutch or brake system failure is corrosion from accumulation of moisture in the brake/clutch fluid. Which in turn is cause by a failure to change the fluid no less often than every two years. That being the case, if one part has failed, there's a good chance that the other will soon. So replace both the master and slave at the same time. And in the future flush the systems every other year.The car makes it possible, but the driver makes it happen.
much truth in this thread.... im finding this out the hard way
bump for some great infoOriginally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.Comment
