Will the M20 survive SEAFOAM?
  • yberther
    • 1246
    Originally Posted by thereisnoyun View Post
    seafoam my car and it did great, but then again, I heard people taht had some serious issues after seafoaming.
    As good as the immediate seafoam differences are, it is an alcohol based cleaner and this makes it eat away at the head gaskets, injector seals, and any rubber... which can be detrimental to the engine..
    Flickr
    Originally posted by Indecline06
    For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
    • E30QC
      • 214
      Anyone have pics or a good vid of doing a seafoam? love to see one...
      not sure about the right vacuum line to use
      • nickpdx
        • 679
        There are lots of good e30 Seafoam vids on YouTube. I would use the vacuum line coming off of the fuel pressure regulator that goes into the intake manifold.
        I've run a can of Seafoam through my gas and one whole can through that vacuum line and the difference was VERY noticeable. Smoother idle and pulled noticeably harder.
        • TheB1G Lebowski
          • 593
          Originally posted by SpecM
          -I love NC. No smog tests. Just a simple visual inspection. Sooooo easy to pass...
          Yes sir and im an inspector in surry co.
          1989 325i - sold
          1987 RX-7 Turbo II - sold
          1990 325i
          • 884door
            • Nov 2008
            • 380
            If you put seafoam in your oil I'd recommend you change you're oil shortly after (maybe 100 miles) Although it is probably eating up some of the gunk in your engine, that gunk has to go somewhere (suspended in your oil) On top of that youve effectively thinned your oil down quite a bit.
            • TrentW
              • 2815
              Seafoam is a petroleum based product that will not damage an engine unless it had a pre-existing defect. Also, if you're going to run it into the intake thru a vacuum line, only use 1/3 can at a time (slowly), as any further volume at one time is just wasted. Keep one hand on the throttle linkage to prevent stalling. Recommend ingesting thru the fuel pressure regulator line also. If the "Check Engine" light comes on, disconnect battery power for one minute and reconnect.
              • TrentW
                • 2815
                Not true. Any deposits will be burned in the combustion chamber.
                Unless you have a blown head gasket for instance...
                • E30_fiend
                  • Apr 2006
                  • 7348
                  dude, this is over a year old
                  • TrentW
                    • 2815
                    "Dude"--why is it that whenever someone starts a new thread inquiring about something that's already been discussed it's time to shit on him for not doing a search, and then when someone adds additional info to an old thread it's time to shit on him?
                    Find something better to do with you post count...
