Bought the car with a broken timing belt, busted rocker arm, and a few bent valves. Took the head apart, sent it to a machine shop all valves, stems, seals were replaced and set, and apparently pressure tested :\ Put the car back together, new water pump, timing belt, all belt, new HG, and it ran rough. Did a compression test to find 180 180 180 180 30 180. Looks like one of the valves is burnt
So I need to take it apart again, if the timing belt doesn't need to be changed, what can I do this time to do this quicker, i'm going to leave the intake manifold on this time since I just had it powder coated and leave the TB on as well.
So far I've taken off all the plugs, airbox, everything on the drivers side, and the distributor, plugs, wires, fuel rail and fuel connectors. Can I remove the head without removing the fan, rad,?
Any help would be appreciated.
