so i started working on my '89 325i because it has 2 broken rocker arms. i am currently about to remove the timing belt but i dont know how to start this, i have already removes the v-belt's, removed the water pump pulley, and i am now stuck. i dont know how to locate where the TDC is and well basically i need some step by step instruction from here..i dont want to ruin my engine by f***ing up something simple like making sure i set the TDC correctly before starting to remove stuff lol. i was thinking i should remove the TB, then replace the rocker arms, install water pump belt tensioner and then TB. soo i just want to make sure everything is done right so once again i cannot locate the TDC on the cam pulley or vibration damper. Thanks for helping!
Edit: wait scratch that i found the marks but theres a problem now..look and see!
and..
and..
