valve adjustment gone wrong? (VIDEO)
  • NC325iC
    • Mar 2004
    • 6565
    alright i just did a valve adjustment (engine just hit ~25k-30k), first time ive ever done one, and in general i dont like taking of the valve cover cause i always screw something up whether its just over tightening one of the retaining nuts and stripping the threads in the head or something else. so i did it the first time yesterday having only read the bentley and i started it and it was running strange, to me it seemed like a cylinder wasnt firing, so i checked the ignition system up to the plugs (i used a spare plug to check for spark on each cylinder) and all was fine. so today i went at it again after reading the pelican article as well as a large number of search results from r3v, i came to the conclusion that i had adjusted the valves too tight. so after getting it to where the feeler gauge was able to move around fairly easily with a bit of friction from both the eccentric and the valve i buttoned everything up again. started it up and same problem.
    the video is being a pain in the ass
    on the video (ive only watched it on my phone, for some reason the audio didnt play on my computer) it sounds alot like a diesel not so much with valve tick but more in the way the engine revs. i still think it isnt running on all cylinders, i may have put the spark plug wires back on wrong, my magnecors arent numbered, is there a test i can do without having to take the case back apart?
    • 34839
    probably just a coincidence - I'd check to make sure you have the plug wires on right.
    • NC325iC
      • Mar 2004
      • 6565
      video, it doesn't sound like an m20, i definitely need to check the wires.
      • deutschman
        • May 2008
        • 5958
        sounds like a tractor! hope you get it worked out!
        • NC325iC
          • Mar 2004
          • 6565
          wire 4 and 6 were switched
          • SamE30e
            • Sep 2007
            • 4319
            haha, it's always the stupidest thing. I changed my plugs yesterday and accidentally dropped one and thought nothing of it. I put them in started it up and one of the cylinders wasn't firing, when I dropped the plug it closed the gap..
            FML.
            1985 325e 2.8 Turbo VEMS
            • SpecM
              • Oct 2005
              • 4531
              FML.
              -Happens all the time! The tip of a sparky plug is like cat's feet
              1989 cirrisblau-metallic 325i
              • NC325iC
                • Mar 2004
                • 6565
                i did manage to destroy a radiator today, theres always one major screw up, i left my breaker on the crank shaft and went for the starter, it wasnt a fun thing, broke the plastic where the top hose connects clean off, luckily i have a usable spare radiator, its just a bit curved
                  • 34839
                  I've done that way too many times. fortunately I've never broken anything.
                  I've also done the switching wire things - I think I switched 1 and 6, so it wouldn't even start though. that took a while to figure out..
