Another Oil pressure light thread
  • Klonsk8
    • Sep 2007
    • 40
    I've search alot in diffrent forums but didnt find the help i need.
    2 or 3 weeks ago my oil pressure light cames on. here's the fact:
    - Manual 325I 91 with 320 000 km
    - i made a headgasket rebuilt 3000km ago
    - I made a Water pump replacement 100km ago
    - I had lots of coolant leak( pump and hoses) before the water pump replacement
    - The light came on as soon i've parked the car in the garage for the water pump replacement
    What i did to solve this issues
    - Change oil pressure switch
    - Seafomed the engine ( 40% vaccum, 30% oil, less than 20% in the gaztank)
    - Made oil change 75 km after the doing the seafoam treatment
    -Reset service light, unplug and replug the battery
    Some little thing you want to know
    -Its seems to always have enough oil in the head.
    - I run the care for at least 100km since the oil pressure light is on.
    -Idle is around 600 or 700 and is steady
    The oil pressure light still on after doing all of this.
    I dont think the oil pump is faulty since i ran the car fo 100km and nothing happens. Also everytime i look in the head (without oil cap on) everything seems well lube. Even is the car hasnt run for like 1 weeks everything llooks ok in the head after turning on the car.
    What should i look for ?
  • Danny
    • 14217
    Leaks.
    • Klonsk8
      • Sep 2007
      • 40
      i will chek for any oil leaks
      thx
        The correct action at this point is to temporarily replace the oil pressure warning switch with a gauge and find out what the oil pressure is. If it is in fact low, the possible causes must be investigated. Those include a too light weight of an oil, clogged or collapsed filter, failing oil pump, or worn engine.
