m54 parts usefull for m20?
  • mark///m3
    • Oct 2007
    • 287
    i have access to an m54 crank, 5 pistons and 5 rods(dont ask)
    i am just curious as if these will be any benifit to my 2.7eta turbo which will someday down the road become a low compression stroker.
    ___________________
    Mark
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    I'm not sure about the rods, but I know the crank is the same size as the S52 crank, 89.6mm stroke. You can create a 3.1L stroker with 86mm pistons. I'll be doing that shortly. People sometimes call them 3.2L, but it's not. FWIW, to get 3195 or 6cc you need an 87mm bore, way too big, IMO.
    • SpecM
      • Oct 2005
      • 4531
      -IF its a m54b30! m54b25's have the same bore/stroke as an m20b25
      1989 cirrisblau-metallic 325i
      • Justin B
        Sikky Nar Nar
        • Mar 2005
        • 4273
        Good catch, truth.
        • SpecM
          • Oct 2005
          • 4531
          -Prob not tho
            • 34847
            you can use the rods and the crank. pistons aren't going to do you much good though, not that a set of 5 rods is very helpful..
            also - the rule of rounding, generally, means a 3150cc engine is considered 3.2l, but 3149 would be 3.1. It's not 3195 - not that you'd get that with an M20. 3.2l would need 86.4x89.6 (3152cc), not 87x89.6. 86x89.6 is 3122, not quite a 3.2, but still larger than a "typical" 3.1.
            • Kingamr
              • Jul 2008
              • 28
              or u can just sell me the crank!
              BMWCCA Member
              http://www.bmwcca.org
