Ok, so I'm trying to get off the lower drivers side and this thing just keeps on spinning but isn't going anywhere. It's not spinning with the bolt eaither. I've turned this at least over a hundred times and it hasn't seemed to make any progress.
I jacked up the engine a tiny bit to see if taking the load off would help. After a bunch more turns nothing.The washer is still tight up against the bracket. Its not getting any easier to turn, same mild resistance... whats up with this?
