Who has actually swapped in an m20 into an m42 318. (help please)
  • omar85
    • 331
    I put an m20b25 from an 87 e30 into my 91 318i. everything is bolted up and it cranks. I have no fuel, and no spark. The #15 connector on the coil pack is for some reason a ground, and i believe it is supposed to be switch power.
    I connected the motronic in the glove box but no of the other smaller plugs. None of them mated up, i;m not sure if i need them.
    Do I need to change some of the pins on the c101 chassis harness connector?
    I need any info you guys can give me. I am totally stumped, and i miss driving my car.
    Thanks.
  • DaveSmed
    • Apr 2007
    • 1407
    Those smaller plugs are whats screwing you at the moment.
    IIRC those smaller plugs are the MPG signal, tach signal, and DME ignition signal for one, A/C input for another, and another one is a mystery. (Something to do with speed input? not needed)
    Also, C101 will bone you a bit as well. Your ABS will stop working as well as the unloader relays until you get that straightened out.
    It's not a difficult swap, but if you don't know that stuff, (or have someone like me to call up, like my friend who did the same swap did ;) ) you'll be pulling your hair out for sure.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • omar85
      • 331
      so how do u suggest i connect the DME ignition signal? thanks for the reply.
      • Shift_Now
        • Jun 2007
        • 91
        I am also interested in this seeing as how I have the same problem...
