Intermittent engine bogging/turning off problem
  • kronus
    • Apr 2008
    • 13032
    Vacuum leak from the pictured hose.
    I went to Lowe's and grabbed 3/4" OD heater hose. It's worked for 3K miles, but I have a stock replacement on order. Look through all your hoses and make sure they aren't cracked.
    cars beep boop
    • mikegar
      • Aug 2005
      • 523
      i checked all the hoses and none seem to be cracked. on a side note where is the pcv valve? does this motor have one? is it incorperated into the valve cover?
      Originally posted by Ferdinand
      I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
      DIVING BOARD DIVISION DIVISION IDIOT
      • kronus
        • Apr 2008
        • 13032
        The ICV (I assume you meant ICV) is a metal cylinder that's connected by a short hose to the back of the intake manifold, and a long hose to the intake boot.
        cars beep boop
        • mikegar
          • Aug 2005
          • 523
          no i know what the idle control valve is. what i am refering to is the pressure control valve, i think it should be connected to the hose that runs from the valve cover to the throttle body.
          • kronus
            • Apr 2008
            • 13032
            Hmm, there is no valve there for me.. the hose just runs from the VC to the throttle body, uninterrupted.
            cars beep boop
            • mikegar
              • Aug 2005
              • 523
              well i figured out what the problem was. im an idiot. when putting the head back on i didnt put injector #6 on firmly so under certian conditions it would become loose and loose contact, till today when it finally came off. pushed it til i heard a click and now it runs fine.
