Cooling problems
  • blck325is
    • Apr 2006
    • 1749
    Cooling problems
    I noticed after driving a bit of a distance that there was coolant on my shoe when I stopped. I have a leak under my dash somewhere. Anyone know what I'm facing here?
    Originally posted by csermonet47
    Vlad, you are handling this quite unprofessionally.
    Also, you are a cock with tacky taste.
    That is all.
  • mattdk318i
    • Jun 2006
    • 3953
    heater core, ive got one if you are in need
    • ethree
      • Aug 2007
      • 1215
      It might also be the heater valve or any of the piping. Either way you're in for a vey enjoyable hour or two of wrenching under the dash!
      • blck325is
        • Apr 2006
        • 1749
        damn. Oh well guess this goes on the todo list. Shite.
        That is all.
        • E30_fiend
          • Apr 2006
          • 7348
          Yeah bro this should go on the, do this weekend list. Its only going to get worse. Make sure you order the hard lines that come through the firewall and the o rings. The hard lines are usually the culprit for the leak so just get in there and check it out. And seriously don't leave it sitting because its most likely due to rust and it can only get worse. It won't fix itself.
          Good luck
          Taylor
          • Hallen
            • 1008
            Not to mention the nasty results of getting coolant in your carpet. It will never leave and will cause all kinds of nasty smells and mustiness and rot.
            1987 E30 325is
            1999 E46 323i
            RIP 1994 E32 740iL
            oo=[][]=oo
              A quick fix for a leaking heater core is to clamp off both heater hoses. A couple of pairs of small needle-nose vice-grips works nicely.
              • blck325is
                • Apr 2006
                • 1749
                Damnnit. I have no time this month. Atleast there's only a couple of drops and not a flood of coolant. Quick fix for now.
                That is all.
