Intake Gasket: No Match!!!
    I pulled the intake manifold off the car last night after work to polish the thing up, give it a sweet metal look. However,
    when i had removed the intake gaskets they didn't match up with the port on the block or the port on the manifold.
    I snapped a few pictures to post up,
    You'll have to notice what got me concerned. The dark outline on the gasket is whats been blocking flow into the engine,
    this gasket is sandwiched only 2 inches from the intake valve. Im thinking this is an incorrect gasket design and may be
    causing loss of acceleration and top speed horsepower.
    So much grease buildup in front of the gasket, all up in the intake pipes. And I know this is affecting the fuel/air flow into the cylinders.
    Anyone ever noticed this shit before?
    Looks like a gasket for an eta.
    Andy
    -Andy
      Andy
      this gasket was found on an iS.
        The etas have a different port shape like the cutout in the gasket you removed, it looks like someone had the intake off before and bought eta gaskets instead of i gaskets.
          My thoughts exactly.
          Andy
          -Andy
            seen it enough times i am not surprised any more when i find one, the usual mo is someone did a head job and got a E head set instead of a I, make sure it doesn't have hex headed head bolts as that is a time bomb if they have been reused, the head of the bolt pops off and gets stuck under the cam making a huge mess of things
