different compresion ratios?
  • T Verdier
    • Aug 2007
    • 2636
    I read in my performance bmw mag today that my 87 m20b25 has a higher compresion ratio than a post 88 m20b25 is that just in a euro car or what?
    • 34847
    yes, they had the option of cars with no catalytic convertors - those cars got higher compression ratios. all the catalytic convertor cars are 8.8:1, including our '88s.
    • akorcovelos
      • Dec 2006
      • 1149
      what was the higher CR on the euro cars? Was this achieved with different pistons using the same 135mm rod?
      2012 MCSCC/NSSCC CP class champ
      HSAX Instructor
        • 34847
        9.7:1 I think. and yes.
        before you go on a wild goose chase though - the bump in compression only made a 2-3hp difference in peak output. I've never seen a dyno comparison between the two engines directly to know if the total area under the curve for the high-comp B25 is significantly larger. My guess is no, because eventually they built all M20s with 8.8:1. the stock cam profile isn't agressive enough to take advantage of high compression.
        • akorcovelos
          • Dec 2006
          • 1149
          yeah, I'm way past sourcing pistons, just curious. I wonder what the motivation was behind going that route?
          HSAX Instructor
          • T Verdier
            • Aug 2007
            • 2636
            not in the U.S. right? because i dont think they would pass emissions without it
            • SpecM
              • Oct 2005
              • 4531
              nope, just in europe
              1989 cirrisblau-metallic 325i
              • T Verdier
                • Aug 2007
                • 2636
                the early engines are marked 84 6e and use a higher compression ratio of 9.75:1 the later engines (post 88 ) are marked 84 6k (the K stands for katalyser) and have a lower compression of 8.8:1. now this is European so witch do i have with U.S. spec 87 325is?
