What is this plug
  • Zyth01
    • 121
    What is this plug
    I found this wire tucked near the firewall right behind the intake manifold. Can anyone tell me where its supposed to be plugged in? I looked all around and didn't see anything with a matching plug.
  • AndrewBird
    The Mad Scientist
    • 11897
    Possibly to the top of the brake fluid reservoir?
    • Zyth01
      • 121
      Brake fluid reservoir has its plug in place.
      • mikegar
        • Aug 2005
        • 523
        it goes to the icv on an eta
        Originally posted by Ferdinand
        I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
        DIVING BOARD DIVISION DIVISION IDIOT
        • Zyth01
          • 121
          There is a plug that looks identical to this one already plugged into the ICV :?
          • mikegar
            • Aug 2005
            • 523
            does the car run? if so how well?
            • Zyth01
              • 121
              It does run, and it runs exceptionally well. Idles at 740-780 all day long when its warm.
              Like I said, I just randomly found this unplugged near the firewall and I don't see anything even close to a match for it nearby.
              In the picture you can see it branches off from a thick black cable that looks like it runs from the battery connection on the fire wall to the fuse box.
              • mikegar
                • Aug 2005
                • 523
                well i might get flamed for this but i would say just tuck it away again.
                • mikegar
                  • Aug 2005
                  • 523
                  i just went and looked at my car. is your water expansion tank pluged in? and i also noticed something on the firewall that might be a temperature sensor, it might go to that.
                  • Rolla1990
                    • 199
                    Self-Destruct switch.
                    Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
                    • Mike
                      • 932
                      Not too sure, but isn't that the connector for the cold start valve on eta motors?
                      Supatek -noun - your basic know it all
                      • Dissembler
                        • Jul 2008
                        • 153
                        +1 on connector for eta motors, my car has 2 plugs like that as well and only one has a home. Runs perfectly. Since your is doing likewise- tuck it away again
                        • Collin
                          • 1736
                          That's in there to provide ballast for the front of the car, maintains your weight balance. Put it back where you found it or your car will handle like a monster truck.
                          The Keystone Killers
                          With 73k+ post, you'd think he'd have learned a little about life.
                          • Matt.nbg
                            • Jan 2016
                            • 8
                            Revival of thread.
                            I have the same issue as OP. Now that it's cold outside, my car is having issues starting due to this plug not having the male end of the connector. No idea where to purchase one either!
                            1985 325e E30
                            1993 525 E34
                            • Kershaw
                              • 11822
                              Junkyard? Dan zimmerman in gaithersburg?
                              AWD > RWD
