headgasket options when going 85mm pistons
  • Mike
    • 932
    I can only assume that if running an oversize 85mm piston (bore size 3.346), that an oe headgasket will not fit the bill anymore. What options are out there, do I have to run a Comotec MLS, or is there anything else out there.
    Supatek -noun - your basic know it all
  • digger
    • Nov 2005
    • 6161
    standard works fine
    • Dyno4mance
      • 345
      MM do one that is modified coolant flow to help against the head cracking in a common area
      2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
