Really Weird Idle+loss of power
  • Atreus
    • 1846
    Okay, so driving to work today, sitting at the light, my idle went from vumvumvuvmvuvmvumvum(you get the idea) to
    vumvum........vumvum.......vumvum. but really loud, and you could feel the engine shaking, like a deep heartbeat. as the light turned green, i gave it some gas and it did not want to go, barely broke 2000rpm, and my CEL came on. now its only happened this once, and i dont know if i can pull a code since the CEL is off now, but has anyone experienced this before? What are some basic things i should look now, to see what the culprit may be.
    Any help is appreciated.
    1991 325iC - Mauritsblau sumthin metallic blue. DEAD
    1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
    1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
    1991 325iC - Calypsorot Metallic
    1994 540i - Granitsilber
    Originally posted by scabzzzz
    I've had blunts cock in my mouth, but I'm not gay.
  • Atreus
    • 1846
    update, i unhooked my ICV and the car died, however i read that if unhooked, the car should rev higher. so does anyone have any leads.
    • ethree
      • Aug 2007
      • 1214
      Unhooking your ICV will cause a huge vacuum leak and kill your engine. I have no idea what your problem might be but I'd start with cleaning your ICV and AFM.
      • Fidhle007
        I can fly, motherfucker
        • Oct 2005
        • 7209
        That can be indicative of a bad AFM or a large vacuum leak. Generally vacuum leaks take more time to show up so I'd suspect your AFM. Read the code and see what's been stored, that's your best indicator.
        '89 325is S50 Track Montser
        '04 X5 Daily/Tow Vehicle
        http://www.avarestoration.com
        http://www.myspace.com/brendanfiddle
        Click here if you want to be my zombie slave...
        http://www.youtube.com/user/Fidhle007
        • Atreus
          • 1846
          thanks for the responses, i really appreciate it. i suspected it was fuel related, so i went to the yard and pulled a FP off a nice 325iS, to no avail. what is the "AFM" is it connected right after the intake? that box looking thing? i'm gonna clean my icv tonight. and try and figure out what an afm is.
          the new FP seemed better for a little bit, but after highway cruising at 80mph, i'd feel the car stutter, and 5miles later it'll die out.
          i'll look into the afm matter.
          • Fidhle007
            • Oct 2005
            • 7209
            What's the code say? And how often have you consulted your Bentley manual?
            • Atreus
              • 1846
              bentley=sold out everywhere. for the past month. so nogo for me. however i have a bunch of pdf manuals at home. (working right now). i was about to post a new thread, asking "how do you pull a CEL code?" the guy told me that my car is ODB1, not OBDII so i can't use their scanner...
              • whiltebeitel
                • Apr 2007
                • 2098
                It's not even an OBD 1 car.
                Do the foot stomp test, or get this:
                http://www.turnermotorsport.com/html...PRODUCT_ID=FCX
                '89 325i track sloot
                '01 530i daily
                -Enginerd
                • wagonizzle
                  • Sep 2006
                  • 443
                  Okay, do a search for "stomp test" and motronic fault codes, if your car is a 1989 or newer. My car did something similar two days after I bought it. I was so dejected. With the help of R3V and $20, my new coolant temp sensor had it running strong and a beautiful relationship was born. I can fix this car!
                  Do your research. These cars are pretty simple so there isn't that much for you to 'diagnose'. Good luck and check the TPS settings too. A Bentley will save you thousands depending on how long you own the car.
                  Originally posted by chileelky
                  amaze about the enthusiasm e30 generate
                  • SpecM
                    • Oct 2005
                    • 4531
                    not so sure where you got that idea
                    to the OP: the AFM sit above and to the right of the air filter housing
                    1989 cirrisblau-metallic 325i
                    • Atreus
                      • 1846
                      perfect, i'll do a stomp test and go from there. thanks a lot for the advice/pointing me in the right direction everyone. stomp test here i go.
                      • Atreus
                        • 1846
                        1-2-1-5 here i come. maf/afm=same thing?
                        • SpecM
                          • Oct 2005
                          • 4531
                          sort of... close enough for the purposes of this thread.
                          AFM codes can also be vaccum leaks in disguise, tho!
                          • Fidhle007
                            • Oct 2005
                            • 7209
                            Try unplugging your AFM and see what happens too, a lot can be learned by how a motor reacts when you disconnect a vital part of it's system. As a professional tech, this is often the first thing I do to a car with weird running problems that my scan tool can't decipher.
                            Think of a your engine's management system like the human body/brain. We use a combination of information from various sources to function every day (sight, hearing, smell, touch) and if one of those senses were to suddenly malfunction, we'd start walking into things. Now imagine you're a doctor and your patient is mute and can't tell you what doesn't work (your car without a scantool.) If you start depriving senses one at a time and watch the reactions, you'll get a pretty good idea of what's not working or malfunctioning. It's a similar situation with a car, but slightly more complex as there are many different things that can cause similar symptoms. But then again, that's why we charge $75 an hour...
                            A quick vacuum leak check (if you don't already know this) is to remove the oil cap while the motor is running. A sputter or possible stall is good, no change is indicative of a leak or AFM issue.
                            Good luck and keep us posted!
                            • Atreus
                              • 1846
                              okay. cleaning my icv+afm now. i am using carb/choke cleaner on both. pulled the gas cap and it did stutter on me, but kept going. gonna take a shot at the TB now..... see you in a hour!
                              wait. will carb/choke cleaner mess up my TB if i use it on that?
