Really Weird Idle+loss of power
  • Atreus
    • 1846
    update: cleaned my icv/afm/tb = car runs smoother now. did a 30 mile test run, no issues.
    however, after another stomp, it still gave me the 1215....is it cleared now? how do i reset it.
    1991 325iC - Mauritsblau sumthin metallic blue. DEAD
    1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
    1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
    1991 325iC - Calypsorot Metallic
    1994 540i - Granitsilber
    Originally posted by scabzzzz
    I've had blunts cock in my mouth, but I'm not gay.
    • SpecM
      • Oct 2005
      • 4531
      Originally posted by Atreus
      pulled the gas cap
      not the gas cap... the oil cap!
      1989 cirrisblau-metallic 325i
      • Atreus
        • 1846
        omg. bwahahahahahah! oil cap oil cap man. god i didnt even notice that.
        • Atreus
          • 1846
          well, in case anyone was wondering, car has been fine. runnin like a champ, i'd like to thank everyone for their help. learned a couple of things.
          thanks guys.
          • whiltebeitel
            • Apr 2007
            • 2098
            So, what ended up causing the issue?
            '89 325i track sloot
            '01 530i daily
            -Enginerd
            • Atreus
              • 1846
              im guessing afm/icv? it was throwing a code for bad afm, i just removed the whole intake and cleaned out everything and double checked the connections, one large can of carb cleaner+toothbrush
              however, i did a stomp and it still gave me a 1215, which is weird because the car has been running smoothly. lowered the idle to about 800, and no more bucking/hesitation.
              how do you clear engine codes anyway?
              • wagonizzle
                • Sep 2006
                • 443
                Pull the negative terminal off the battery and let it sit for 30 mins or more. Whenever I do this, my ECU takes a few miles to 're-learn' what the car likes, but after that it smooths out like normal. For all I know this means there are problems it is adjusting to but you should have no more codes. Drive it for a bit and then do another stomp test; sometimes the check engine light will flash while driving and you may not notice it, and then a code is stored. I believe a 1444 is all clear, but I'm assuming you have a fault code list. Good luck :D
                Originally posted by chileelky
                amaze about the enthusiasm e30 generate
                • Atreus
                  • 1846
                  perfect. thanks a lot. lets hope i get fourteen forty four'ed.
                  • lukem23
                    • Mar 2008
                    • 296
                    i had a similar problem with my 1986 325es. the PO decided to take the AFM cover off and cylicone it back on. every now and then it shutters, but i just have to get out and check the cover.
