2.7 crank
  • THATDONFC
    • Jun 2008
    • 639
    2.7 crank
    Will it fit in the 2.5 block with LC pistons?
  • E30_fiend
    • Apr 2006
    • 7348
    The B27 and the B25 blocks are exactly the same. So to answer your question, yes the crank and the pistons with fit.
    Taylor
    • THATDONFC
      • Jun 2008
      • 639
      I put the crank in the block last night and the i pistons dont fit. I put a head on and rotated the crank. The pistons come up pretty far past where they use to. I'm thinking a thicker HG and some LC Pistons and I should be set in that department. How much of a HP gain do you think I'll get with the stroke of the eta on the i?
      • jmc1590
        • Jul 2008
        • 112
        While the blocks are the same, the contecting rods are different, as are the pistons. Trying to use the 2.5 connecting rods and pistons with a 2.7 crank will cause the pistons to hit the head! Using the e rods and the super-e pistons is one accepted solution....
        • THATDONFC
          • Jun 2008
          • 639
          yea but with LC pistons there is no bulge at the top leaving more room for piston travel. Along with a thicker HG I think it just might work. However I'm gonna pick up new rods and pistons anyway...
          • h82crash
            • 127
            Read the forums man! This has been tried probably a million times before and it don't work. People have even tried to shave the pistons. Either find yourself some '88 seta pistons and use them with your eta rods or you're gonna have to buy new pistons that have the correct height.
            "Life is hard...it's a lot harder if you're stupid."
            Tom
            72 2002
            87 327i
            88 525i
            88 535i
            03 530i
            • SpecM
              • Oct 2005
              • 4531
              what the heck is an LC piston?
              1989 cirrisblau-metallic 325i
              • Todd Black 88
                • Oct 2007
                • 3449
                You need 130mm rods . Period. The 325 rods are 135mm. They will not work.
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                • THATDONFC
                  • Jun 2008
                  • 639
                  low compression
                  • mikegar
                    • Aug 2005
                    • 523
                    i love low depression crank.
                    Originally posted by Ferdinand
                    I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
                    DIVING BOARD DIVISION DIVISION IDIOT
                    • Motorsports
                      • Feb 2007
                      • 2882
                      What compression are you trying to run.
                      • THATDONFC
                        • Jun 2008
                        • 639
                        Well I'm not sure. I just recieved a 2.5 block with the 2.5 crank as well as a 2.7 crank. I'm gonna start building this motor slowly but surely as the money comes in. I have someone assisting me with this process. It will be a learning experience for me. I'm not to savy with motors so I will learn a lot in this process. What would be ideal compression if I bore the motor to 2.9/3.0?/
                        • SpecM
                          • Oct 2005
                          • 4531
                          are you planning to boost?
                          I say stick with the 2.7 crank, 130mm rods, and s-eta pistons.
