white smoke
  • smellslikecurry
    • 104
    white smoke
    this all pertains to a 1984 325e...stock everything...no chip...177K miles
    after a rusty exhaust incident on the highway i recently i had a new exhaust welded on...no cat just 2.25 inch straight back to a dynomax
    under deceleration lots of white smoke comes pouring out but only when the revs are really high up and theres a good amount of back pressure...i have no overheating problems and when im driving theres no white smoke
    is this just extra unburnt fuel from running a little rich without a cat or is it coolant? my coolant levels seem fine
    my mpg did go down slightly after the exhaust
    anyone have this problem?? think it could be the valve seals? i dont know if im getting blow by the rings...
    White smoke is vaporized coolant, so it sounds like you have a leaking head gasket.
    • smellslikecurry
      • 104
      i thought if it was the head gasket there would be constant white smoke
      not just white smoke after deceleration
      • ethree
        • Aug 2007
        • 1213
        Have you thought about getting a cat put back on?
        • smellslikecurry
          • 104
          no why??
          • smellslikecurry
            • 104
            anyone else? it hasnt happend in a few days...and no its not water condensation
            • JasonC
              Site Manager
              • 14451
              The no cat has nothing to do with it.
              Sounds like the rings though. But then it would be more of a blue smoke.
              1992 BMW 325iC
              1978 Chevrolet Monte Carlo
              • Devil Inc
                • Jan 2008
                • 802
                Over fueling would be black, carbon rich smoke. iirc.
                • ADEN
                  • 620
                  you seems to go very fast if yes then your rings starts to leak.
                  I'm having a black color exhaust i don't know what to do and my BMW consume a lot of gas.
                  • Quailane
                    • 131
                    Definitely sounds like something wrong with your fuel system.
