Going to look at a e car that might have a head swap; it's past history is a little vague but the motor has been worked on. Is there anyway to tell from just looking under the hood the difference between an "e" and "i" cylinder head?
325e head vs 325i head
Jeremy Lucas
FastTechLimited.com Race Technology, AIM, Race-Keeper, DriftBox/PerfomanceBox, Aplinestar, Schroth, etc...
1991 SpecE30 #53
2001 325iTTags: None -
yes look for the casting number. the e will end in 200, and the i will end in a 885.Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOT -
If you are used to looking at them, there is a HUGE difference in intake port sizes, plus the shape is quite a bit different.Comment
easiest way with the head on the car and the manifolds on would be to look at the casting number on the head.Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTComment
