The car cranks, but won't start. The fuel pump won't run, and I've got no spark. The voltage at the fuel pump relay reads 12V until I crank the motor, then it drops down to 2-3V. the battery reads 12V but at the other end of the small cable(w/ fusable link) I read 12V until I crank or put the ingnition to run, then it drops down to 2-3V at the block on the firewall. If I wait till the next day, it does it again(starts at 12v then drops down to 2-3v and stays that way as long as I'm trying to test it). WTF!
Cranks but no start?
Tags: None
It was corrosion!!!
the fusable link was corroded! I started checking voltage through the cable jacket, and when I got to the link, I had 12v on one side, moved 1/8" over, and nothing. I couldn't even read continuity through it, so...
Now what do I replace it with?Comment
I am using an AGU type car stereo fuseholder, available at most all car stereo shops for about $10 and a 50A fuse.
$.50 fix
I spent $50 to get the car towed home:(, and $.50 to fix it with six inches of fusible link wire.:DComment
Where is it on an 86 325e? Would jumpstarting the opposite terminals of the batteries blow this? (non Bmw owners should never be trusted with jumper cables LOL)Originally posted by alpinacloneSince the real economy is in the shitter, I say we start our own.
This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.Comment
