So i've been searching around and asking and have gotten most of the info i need, but im looking to complie a complete checklist of shit you need for the 2.7i
Specifically mine, which will be the eta bottom end [on my '86]
And sourcing parts from an 87i, still an early model
So
The Head
Intake Manifold
Fuel Rail and injectors
Fuel Pressure Regulator
Idle Control Valve
ECU
Spark Plug wires & trigger
ECU harness
Air Flow Meter
Thermostat Housing
crank position sensor w/bracket.
Big round thing with all the notches in it that goes behind the main pulley.
Throttle body.
What am i missing? anything unnecessary?
Thanks!
Stephen
So
The Head
Intake Manifold
Idle Control Valve
ECU
ECU harness
Air Flow Meter
Thermostat Housing
Throttle body.
Thanks!
Stephen
