Differences between 87 and 89 M20 motors?
  • bmwpower
    • 1556
    I know the water pump is different and the hose routing, but is there anything else?
    89 325is track project / 05 x5 / 99 M3
    E30 stuff for sale | Parts I'm looking for
  • mikegar
    • Aug 2005
    • 523
    which m20 motor? i think the blocks are the same its just the variants that are different. such as m20b25 and the m20b27 are different, and the 87 and 88 m20b27 are different.
    Originally posted by Ferdinand
    I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
    DIVING BOARD DIVISION DIVISION IDIOT
    • bmwpower
      • 1556
      Sorry, specifically the 87 325i and 89 325i engines. So I guess those would be m20b25.
        The water pump, injector rail, and engine harness differ between an 87 and 89 M20B25. You can use either engine by swapping parts from one to the other. You can use the harness from the wrong year, but depending on which way you are going the alterations required vary. The easiest is using a late model harness in an early model car. There it is only necessary to provide wiring for the tach and start signal.
        • bmwpower
          • 1556
          Originally posted by jlevie
          The water pump, injector rail, and engine harness differ between an 87 and 98 M20B25. You can use either engine by swapping parts from one to the other. You can use the harness from the wrong year, but depending on which way you are going the alterations required vary. The easiest is using a late model harness in an early model car. There it is only necessary to provide wiring for the tach and start signal.
          Thanks....Is the coolant hose arrangement at the thermostat housing different?
          • StereoInstaller1
            GAS
            • 22679
            yes
            Closing SOON!
            Thanks for 10 years of fun!
              • 37829
              Motors themselves are exactly the same though, fyi.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • E30_fiend
                • Apr 2006
                • 7348
                The coolant reservoir is in a different location and the radiators are different I believe. The hoses route differently from the radiator.
                • SpecM
                  • Oct 2005
                  • 4531
                  and the only difference in the fuel rail is the location of the feed line, but they are completly interchangeable
                  1989 cirrisblau-metallic 325i
                  • sandlock
                    • 946
                    what if any are issues using a 87 m20 in a 89 using the late harness and ecu? I noticed my original 89' harness has two extra pins compared to the 87 harness. I believe more was routed through the ecu in later cars than the early. If the motors are interchangeable, should i be swapping the original harness onto the older motor along with the coolant/fuel rail stuff and running my original ecu with it to save hassle since the motors are the same?
                    ReverseOTL.
                    NewParts4sale.
                    PartsWanted.
                    • StereoInstaller1
                      GAS
                      • 22679
                      They are NOT the same block. The '89 and newer has different motor mount bosses, but that won't change anything on an E30.
                      Closing SOON!
                        Use the harness, fuel rail, and coolant system stuff from the 89. It would be best to install a new timing belt, tensioner, and water pump.
                        • StereoInstaller1
                          GAS
                          • 22679
                          and of course that means tiny bit of fabrication on the late model radiator, NBD.
                          Closing SOON!
                          • sandlock
                            • 946
                            Thanks jlevie, that's exactly what I deduced. I'll look into the new waterpump, but the new belt and tensioner have been covered.
                            ReverseOTL.
                            NewParts4sale.
                            PartsWanted.
                            • bernzpeed
                              • 3917
                              i did a swap on mine. i have an 87 325i donor car and an 89 325i. i took the 87 and put it in my 89. the hoses for the oil cooler used were from the 87 since the one from the 89 didn't work. some other parts were used as well.
                              89 E30 S52
                              Transaction Feedback.
