Random engine 'hiccups'
  • bejbis
    • Dec 2008
    • 596
    [first post] I purchased a 89, 325i 5 speed a couple weeks ago, so far i love the car, but it just started giving me a bit of trouble. Driving down the road, constant speed, no throttle changes, the CEL light will flash very randomly, and sometimes the engine will just die. usually for 3-6 seconds, the engine will loose power, it feels like spark is cutting because it will happen very suddenly, the CEL light will come on and headlights and interrior lights will all still be on while the engine is off, and while the car is in gear coasting the engine tach will fall to 0, i dont know how these cars get their tach signal, but it leads me to believe ignition.
    ive searched and read back probally 15 pages in the m20 forum, but cant find an awnser, but from what ive found im leaning twards the crank position sensor.
    -Dan :up:
    -Dan
  • CarsSuck
    • Oct 2005
    • 968
    yup. CPS is your #1 suspect. See my thread "cold running issue" near the bottom of this section.
    Check it with an ohm meter. bently manual says 540 ohms +/- 54, iirc.
    --Will
    • bejbis
      • Dec 2008
      • 596
      just drove the car up the road, new symptom, the car surges a little bit under constant throttle.
      CarsSuck: where is the CPS on the 325i? ive read that on E's its on the tranny bellhousing, and on the front cover, and on the I there is just one on the front cover, is this correct?
      -Dan
      • Kingb
        • 928
        It is on the front of the engine on the pass side below the oil filter but up by the crank pully
        Originally posted by Nicademus
        My car beats off to that car. :bow:
        • acefreely02
          • 19
          did you replace it? any verdict??? my cars doin some strange things like this... i dont have an ohmmetter to check shit tho.. and i dont have a garage to work on it...
          • hoveringuy
            • Dec 2005
            • 2753
            Read your spark plugs. Is it running rich? Normal? Lean?
            • bejbis
              • Dec 2008
              • 596
              i plan on ordering a CPS and coolant temp sensor, i figure i will need one of each eventually. however, i dont know the best place to order these things, ive heard of bavauto.com and possibly pelican parts, wondering if anyone had any reccomendations as im new to BMWs
              -Dan
