what happens if FPR vacuum hose is leaking?
  • hahmeta
    • May 2008
    • 213
    as I'm changing my spark plugs tonight I realized the vacuum hose from FPR to intake manifold is almost cut in half right at the FPR. what does this mean? should I not drive the car?
    thanks a lot guys
  • e30evolution
    West Werks
    • 1888
    means your fuel pressure will be higher than it should be, and you have a vacuum leak... replace the hose, but you can drive it
    http://www.westwerksauto.com
    • hahmeta
      • May 2008
      • 213
      is it a BMW specific hose or can i get the same diameter from any auto parts store?
      thanks for the help.
      • hahmeta
        • May 2008
        • 213
        also should i expect any difference in engine behavior with vacuum hose leaking? for instance should the engine idle at higher rpm? or something like that. i'm trying to understand if i should check the fpr while i'm at it.
          At idle the fuel pressure would be too high and thus the injectors would be delivering a bit more fuel for each firing pulse. But with the hose severed, you'd have an intake leak which would tend to counter the fuel increase. So there may not be all that much of an affect.
          The hose in question can be replaced with generic vacuum hose, which you can get at any auto parts hose. Take the existing hose with you and then can match up the ID.
          • eugeman
            • Sep 2007
            • 306
            Or, you could cut the hose off before the cracked part and slide it back on, voila, problem fixed. Then you could find an equivalent hose thereafter at your convenience.
            • SpecM
              • Oct 2005
              • 4531
              yea, just get some cheapo generic rubber hose
              1989 cirrisblau-metallic 325i
              • hahmeta
                • May 2008
                • 213
                thanks guys. took care of it today along with new injectors. old ones were filthy! time for seafoam i guess.
                  • 34839
                  you have it backwards, it will be lower. fuel pressure *increases* with engine load (vacuum), it doesn't decrease.
                  • SpecM
                    • Oct 2005
                    • 4531
                    no, he was right. Manifold vacuum decreases with higher load.
                    engine load goes up (more throttle), engine vacuum DECREASES, the FPR valve closes (kinda), and fuel pressure goes up.
                      • 34839
                      a bit on the semantics side, but that's what I meant. Fuel pressure increases with engine load (proportional to vacuum).
                      • Mike
                        • 932
                        I am actually having something a little different. At idle, I have my needle shaking between 40-43 psi, and the pressure goes down to mid 30's when revved. If I pull the vaccuum line, and plug the manifold side up, fuel pressure stays a constant 43psi when revved. The needle also smooths out. What does that mean? This is no stock m20, btw...
                        Supatek -noun - your basic know it all
