NGK Spark plug?
  • Dyno4mance
    • 345
    NGK Spark plug?
    What NGK spark plug can I use on a 2.7 stroker w/885 head? Are they a heat range 5 or 6?...I have not had much joy with Bosch in the past so I would prefer to stay away from them
    Thanks
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
  • Dyno4mance
    • 345
    What plugs do most people run then???
    • digger
      • Nov 2005
      • 6194
      BPR6ES if you have a reasonable CR (colder plug than stock) other wise ZGR5A (stock)
      • Dyno4mance
        • 345
        Thanks....Great info, at 11:1 I am sure I would need the BPR6ES....Thankyou digger
